Survey mission incorrect time with Blueboat
We experience that de calculated total mission time is incorrect. Our plan is 4221 m to survey with our Blueboat. The calculated mission time is only 4 min and 41 seconds. With a surveyspeed of 1 m/s its incorrect. It should be around 1 hour and 10 minutes.
Is there a setting somewhere i need to adjust so we can see the right time? Its a valuable tool for us to know the mission time for overal planning.
First step try a daily build. Also make sure you are setting up for flight speeds in Mission Start so time calc knows what to do. If all that still doesn’t work. Create an Issue on Github and include the Plan file and Ill take a look.
