cbf123
(Chris Friesen)
May 12, 2022, 10:56pm
#1
I wonder if it might make sense to add
–user “$(id -u):$(id -g)”
to the docker commandline in the documentation for running the container to build Ardupilot? Without it, if you just blindly follow the instructions it will end up hitting a permissions error when it tries to create the “tasklist.json” file within the container.
please do a github.com pull request with that change
cbf123
(Chris Friesen)
May 13, 2022, 7:39pm
#3
Turns out it’s a bit more complicated, because if you run with that added to the docker commandline then the user isn’t in the right groups in the container.
I ended up doing a “chown -R” in the container to take ownership of the source, but then I had to muck with permissions again to edit the files outside of the container.
Might be simpler to edit the group membership within the container the first time you run it.
zacroker
(Zac C)
May 26, 2022, 12:16pm
#4
I had a similar issue - I have made a PR with a solution which is a bit cleaner than having to do chown -R as you’ll end up mucking up the permissions on your docker host
opened 04:53AM - 26 May 22 UTC
DevEnv
## Bug report
**Issue details**
Docker has permissions issues. In the wiki t… he relevant instructions can be found [at this link](https://ardupilot.org/dev/docs/building-setup-linux.html#how-to-build-the-docker-image).
1. `docker build . -t ardupilot`
2. `docker run --rm -it -v `pwd`:/ardupilot ardupilot:latest bash`
When you are in the container and trying to build etc, you get permissions issues as the user in the docker container is 'ardupilot' with uid/gid 1000. Hence when you volume mount the user/group are the local user/group and unless they are uid/gid 1000 you cannot create the file 'tasklist.json'. See the below log output for an example command in the container.
ardupilot@1ca879292c95:/ardupilot/ArduCopter$ sim_vehicle.py -w
SIM_VEHICLE: Start
SIM_VEHICLE: Killing tasks
SIM_VEHICLE: Starting up at SITL location
SIM_VEHICLE: WAF build
SIM_VEHICLE: Configure waf
SIM_VEHICLE: "/ardupilot/modules/waf/waf-light" "configure" "--board" "sitl"
Traceback (most recent call last):
File "/ardupilot/modules/waf/waflib/Scripting.py", line 158, in waf_entry_point
run_commands()
File "/ardupilot/modules/waf/waflib/Scripting.py", line 248, in run_commands
run_command('init')
File "/ardupilot/modules/waf/waflib/Scripting.py", line 235, in run_command
ctx.execute()
File "/ardupilot/modules/waf/waflib/Context.py", line 204, in execute
self.recurse([os.path.dirname(g_module.root_path)])
File "/ardupilot/modules/waf/waflib/Context.py", line 286, in recurse
user_function(self)
File "/ardupilot/wscript", line 91, in init
generate_tasklist(ctx, False)
File "/ardupilot/wscript", line 565, in generate_tasklist
with open(os.path.join(Context.top_dir, "tasklist.json"), "w") as tlist:
PermissionError: [Errno 13] Permission denied: '/ardupilot/tasklist.json'
**Version**
Latest master
**Proposed Solution**
My proposal for a solution is as follows. The Dockerfile has uid/gid 1000 as default, but they can be overridden by a build argument e.g.
FROM ubuntu:20.04
WORKDIR /ardupilot
ARG UID=1000
ARG GID=1000
Then the build instruction would be: `docker build -t ardupilot --build-arg UID=$(id -u) --build-arg GID=$(id -g) .` to copy the uid/gid of the local user to the built image.
The limitation is that the ardupilot image would be useful only on that machine.
