Hi all,
I am suffering from several issues for some time, all of them looks the same but happening in different cases and different times.
the problem looks as sadden change in altitude when switching to mode or arriving to WP
I have placed a system (Sky walker 2014 - T tail frame) with pixhwak.
I have set it up according to all of the instructions in the ardupilot website.
I have install firmware 3.2.3 on it and load the parameters on the Aero-m located in mission planner.
Attached are the telemetry log files of the last flights:
- Flight from 01.09.15 the problem accord in when switching to stabilized and to auto mode (30.2% of the log file). The next time accord when switching to auto mode (32.0% of the log file)
Flight from the 26.08.15 the problem accord when in auto mode (20.0% sadden climb in the altitude that led to stall. since that happened the plane did not enter to WP 3 and he was straggling to do so.
The problem appeared also in 25.9% of the log. Then I took over to manual and continue with manual mode.
it is really fostering since I have also established a system of Quad based on pixhwak with no issues at all (walk in the park……)/
Please can you advice what is wrong according to the log files.
My next option is to downgrade the system to APM 2.6 and see how it goes.
Thanks in advance for your kind help!! Im pretty lost here …
Benny
