Sub-4.7.1-beta1 has been released for beta testing and can be downloaded using Mission Planner, QGC or directly downloaded from firmware.ardupilot.org.
The list of changes vs 4.7.0 are in the ReleaseNotes and copied below.
- Board specific changes
- ARKV6S board added (@dakejahl, PR:33157)
- CORVON_V5 board added (@holydust, PR:33593)
- DAKEFPV boards add support for LSM6DSV and BMI270 IMUs (@engineer-dakefpv, PR:33984)
- FlywooF405S-AIO and -HD boards support SPL06 barometer (@mbuzdalov, PR:33779)
- KakuteH7-Wing boards support LSM6DSV IMU (@zebulon-86, PR:33761)
- ORBITH743v2 board added (@orbittechnologyx, PR:33582)
- Plane specific changes
- Q_P_JERK_NE/D renamed to Q_P_NE/D_JERK (@rmackay9, PR:33843)
- Quadplane: In transition only set TECS throttle min in auto throttle modes (@IamPete1, PR:33972)
- Copter specific changes
- Auto mode climbing Arc waypoint speed limits and velocity/acceleration fixed (@lthall, PR:33833)
- Auto mode fix to continue past RTL if rtl-final-descent non-zero (@rmackay9, PR:33797)
- Circle mode entry fixed when RC input present (@peterbarker, PR:33525)
- PSC_JERK_NE/D renamed to PSC_NE/D_JERK (@rmackay9, PR:33843)
- Simple mode fixed (@rmackay9, PR:33947)
- Library/Driver changes
- AC_WPNAV: Use of uninitialised values avoided in m/cm conversion code (@peterbarker, PR:33715)
- AP_Filesystem: Files without an End-Of-Line character get correctly read (@peterbarker, PR:33744)
- AP_FlashStorage: Fix incorrect value of
current_sectorduring init (@Juergen-Fahlbusch, PR:33640) - AP_Follow: Fix parameter ranges to include their defaults (@lthall, PR:33928)
- AP_GPS: Unicore baseline correction in vertical component of Unicore reported baseline (@lthall, PR:33730)
- AP_Mount: Fix AlexMos yaw angle scaling (@borischernov, PR:33785)
- AP_NavEKF: Log per-core source set in XKFS (@mykhailopylyp, PR:33904)
- AP_OSD: use Betaflight SYM_TOTAL_DISTANCE for DisplayPort distance icon (@coreyfarley, PR:33908)
- AP_RangeFinder: TFMiniPlus: Small delay added to improve read reliability (@IamPete1, PR:33709)
- ChibiOS: fix overdrive disabled on H7 boards clocked above 400MHz (@andyp1per, PR:33824)
- GCS_MAVLink: Correction in diagnostics printing (@peterbarker, PR:33800)
- IST8310 compass gets probed only if the driver is enabled (@peterbarker, PR:32696)
- Topotek gimbal network connection handling is corrected (@peterbarker, PR:33803)
- Tool changes
- build_options.py: Wrong dependecy for MAVLINK_SIGNING has been removed (@peterbarker, PR:33798)
We would like to get the simple mode fixes out quickly so we are only planning for a 1 week beta period this time so any and all feedback is greatly appreciated!
