Got everything working then when plugged in the radio inputs works but servo don’t move, tried resetting
SpeedyBee 405 wing
Will add more setup
The file is password protected.
Servos won’t move when the plane isn’t armed unless you set the BRD_SAFETY_MASK for the appropriate channels. Note the throttle output will still only work when armed no matter what you do with this parameter.
IIRC boards without safety switch input often are configured to boot to safety off state.
The values don’t centered like was before, now you should see pic
Video didn’t help. Set LOG_DISARMED,1 and do that again. Post the .bin log file.
changed those values
ecli_bin.param (19.0 KB)
That’s not the .BIN file I asked for, but it’s a start.
You have no ailerons set up, only rudder, elevator, and two throttles. If one of those throttle outputs is supposed to be ailerons that will be the problem because the trim values for both are set at 1100.
Sorry forgot change back aileron after checking if had ant movement, but still don’t get expected values, have setup in radio as before when working, spot any mistakes?
.bin how do i find it?
Follow guide, No logs to select. If you check vid folder there a pic on output if helps. Thanks
