Stabalize flight mode can not arm without GPS?
I have done all the calliberation. My motor test is done and working quite well . All the parameters are good after using pixhawk 2.4.8 . I am not using any gps …only stabalize mode . but the problem is I am facing is the arming of my tricopter . Please anyone help me in this regard .
My WhatsApp number : +8801886062062
I would be highly obliged if anyone helped me by some quality time . Any help and advise is appreciated …thanks in advance
You may want to look at the configurator and see what you have missed or sequence.
You need to disable GPS arming checks in the bitmask.
IIRC the proper step would be to disable both GPSs in params if it isn’t used.
Do what @LupusTheCanine said instead. Its better
