stefymtb
(step)
November 17, 2024, 12:47pm
1
So i have Holybro sik radios.
Where should i plug the one on the plane?
I do not know the numbering of the uart on the board.
Also i know nothing about the wiring, as no port seems to be labeled with same names from sik radios.
Below is the port i am using. Have no idea if uart 6 or other.
Also, the radios are connected. but can not connect to mission planner.
No heart beat. Correct port and baud.
stefymtb
(step)
November 17, 2024, 1:14pm
3
I know this of course.
But could you point what is uart6 on the image pls?
I can not.
stefymtb
(step)
November 17, 2024, 1:22pm
5
After even more reading, i came to a conclusion that my external telemetry radio is actually most likely connected to Serial 4 port, because the solder pads on the board say “R4” and “T4” which, I think, correspond to Serial 4. After changing SERIAL4_PROTOCOL to 1 (MavLink 1) or 2 (MavLink 2) On Mission Planner via USB, I still can’t connect to the board via Telemetry, am I missing something?
Also sorry for all the mistakes I make, I can fairly say that I’m still pretty new to these new devices…
I had a look at this topic.
So main problem is i do not know what port number i am connected to. How do i know it if it is not written on the board or manual?
dkemxr
(Dave)
November 17, 2024, 1:26pm
6
Why not? Use UART4 (Tx4/Rx4) or the UART5 on the DJI Connector if you are not using that.
stefymtb
(step)
November 17, 2024, 1:31pm
7
I am using dji vtx, gps (they are close) and usb plug module.
I plugged the sik radio on the side instead.
As shown in the picture i uploaded.
Is that what uart number?
Because i know uart 6 may not be available bevause of wireless module?
So, if not that, what number? Where is it on the board?
Edit: is the numer after tx/rx the number of the uart?
dkemxr
(Dave)
November 17, 2024, 3:05pm
8
6 is not available and the uart/serial port numbers are right in the wiki and in my last post. What else would Tx4/Rx4 be? Connect to Tx4/Rx4 and configure with Serial4
Note: I don’t use F4’s or Speedybee Flight Controllers, just following the available docs. Maybe someone else has something to contribute.
stefymtb
(step)
November 17, 2024, 3:24pm
9
Please be patient.
This is not my first model, but this time seems like it is a little bit more difficult with this new fc.
The problem i had (it is almost clarified now) was to know fisically on the board what was uart1, what was uart2…
Now i know that i can refer to numbers near rx/tx.
If i look at tx1, i can find it in two diffent places…but i will find this out later…now i am focused on the sik radios.
Thank you Dave!
dkemxr
(Dave)
November 17, 2024, 3:45pm
10
It might help too to look at the Ardupilot Mapping table in the Speedybee manual.
stefymtb
(step)
November 17, 2024, 4:09pm
11
I can see it now. I am connected to Tx2/Rx2
I change that parameter and it should work.
What about the cables called RTS and CTS?
They will be on Tx4/Rx4
Allister
(Allister Schreiber)
November 17, 2024, 5:09pm
12
You don’t need RTS an CTS for the SiK radio. Just the RX,TX,5v,gnd.
stefymtb
(step)
November 17, 2024, 5:29pm
13
It’s working!
Set serial# to mavlink
Set serial# baudrate
Thank you so much! Sometimes solution is in front of my eyes and i just can’t see it.
Do i need to remove RTS and CTS cables or they can stay there?
Allister
November 17, 2024, 5:47pm
14
It’s up to you. If you don’t connect them it doesn’t really matter as long as they aren’t getting in the way or shorting something else.
