I’m having an issue with my SpeedyBee F405 V4 and Mission Planner: Serial 0 is automatically set to MAVLink and can’t be changed. I need Serial 2 for MAVLink as I want to establish the connection via UART, but USB is blocking it. No matter what I try, Serial 0 stays on MAVLink, and I can’t activate Serial 2 for it. Does anyone have a solution?
I Changed serial0 to -1 to deactivate the usb Port but i also changed it to Other Numbers Like 23 to Test but mavlink1/mavlink2 did Not change at all i cant pick none or something Else it always Shows mavlink 1/2.
The Problem is that my raspberry pi cant find my fc if i want to Connect With mavproxy.
Did you find a solution for this one? I am considering a Speedybee 405 V4 with O3 for video and command and would like to add a mavlink tlemetry connection on one of the UARTS.
