Hi, I have connected my matek h743 wing and matek m9n-5983 GPS together and connected to arduplane through mission planner. Under the compass priority page, no compasses show up. Thanks in advance for your help
I having the same issue using a mRo GPS and the Kakutef7. normally you just reverse the wires until it works. the compass seems to show up in the calibrate page but not sure if its just a false read. Iβm new to setting up this board. possibly check your setting in the config should be set to 5 with the correct baud rate,
I got it to work with SERIAL3_PROTOCOL 5 donβt forget to swap tx and rx .
Just realised my mistake, swapped the da and cl wire. Thanks for your help
That should be put in the thread title (SOLVED-Wires swapped).
