I got a Holibro Pixhawk 4 a while ago and started building Y6B copter only recently. For some reason there is no PWM output from the Pixhawk goint to the motor Main3. I am sure Holybro won’t help with the warranty so my question is:
Can I change mixer settings and redirect signals to a different channel, tet’s say Main7?
Where these settings can be changed?
Thank you.
Sure you can, just assign it with the SERVO7_FUNCTION to 35 and set the current Servo out channel to 0. This is not a common problem though, post your parameter file perhaps there is something to see.
My parameters are still default since I just assembled the frame, mounted motors and was about to check the rotation direction.
Y6_default.param (16.9 KB)
Looks OK for a default Y6B.
