I got a weird error today.
Was just sitting at the field…Had just powered up the quad when a minute or so later I got the announcement Smart RTL disabled Buffer full. What the heck. I have never run into that one before.
Hi Ricky- I have seen that many times. If you want to continue to use Smart RTL on long flights increase the SRTL_ACCURACY value from default (2m) so the buffer doesn’t fill.
Strange…
SRTL only had 7 points (from somewhere…) when the maximum was set to 300. You’ve got GPS settings but nothing is logged for it, there’s Lat and Lng readings in the log though.
Hey Shawn.
Ya it’s really odd. I rebooted the craft and the error went away. I had no further error of that nature. I will keep an eye on it and report if it happens again. Very odd.
The problem I am up against now is I keep getting the message Trim Saved…huh. Why.
Will check my config in case I set something wrong.
