SmartAP PDB - integrated buzzer
I am trying to connect the integrated buzzer located on the SmartAP PDB to a Cube Orange+ flight controller using the AUX5 servo output (servo13_output). In Mission Planner, I have configured servo13_output to “Alarm.” The buzzer works, but the volume is very low, likely because the voltage it receives is too low.
I am considering connecting it to the dedicated pin on the ADS-B Carrier Board (USB/SERIAL6 port), but I am concerned about the risk of a short circuit.
According to the Cube Orange+ manufacturer, the “buzzer” pin carries the battery voltage. This is confusing to me, given that the flight controller is powered by 5.3V, while the battery connected to the SmartAP PDB operates at 44.4V.
Do you think it is safe to connect the buzzer from the SmartAP PDB directly to the “buzzer” pin on the SERIAL6 (USB) interface?
The Cube has an internal step-up regulator to drive the standard buzzer with enough voltage as per this:
The SmartAP PDB instructions are not too clear about what the two buzzer wires do and what voltage they are expecting. I suppose you could try connecting to the BUZZER_OUT pin of the USB/Buzzer port on the carrier board.
I have received information from the manufacturer that the operating voltage of the integrated buzzer is 5V.
When connected to the BUZZER_OUT pin of the USB/Buzzer port on the carrier board, the buzzer works, but it is not as loud as the one included with the Cube Orange+.
It is likely that at a distance of 10 meters from the drone, which will have an enclosed PDB, the sounds will be inaudible.
Yes, I’ve found the buzzer is of limited value. Even a loud one can not be heard when the copter is more than a couple of meters away. It’s better to set up some neopixel (WS2812B) or profiled strips of LEDs on the arms. You can have them show the arming status and more.
Use a script to illuminate left and right arms for orientation. These imitate the pre-arm status (yellow and so one) and change to red and green with white strobe when armed.
I use red on the left and green on the right, same as aviation and shipping. I’ve never worked out why a lot of people use a red light on the back of a copter like a car tail light.
 Script to use LED strips as position lights.
 For this script we will use two strips with up to 8 LEDs each.
local num_leds = 4
local timer = 0
-- Brightness for green or red light.
local br_color = 128
 -- Brightness for flash light when armed.
local br_flash = 255
 Use SERVOn_FUNCTION 94 for left LED strip
 Use SERVOn_FUNCTION 95 for right LED strip
local chan_left = assert(SRV_Channels:find_channel(94),"LEDs left: channel not set")
local chan_right = assert(SRV_Channels:find_channel(95),"LEDs right: channel not set")
-- find_channel returns 0 to 15, convert to 1 to 16
chan_left = chan_left + 1
chan_right = chan_right + 1
gcs:send_text(6, "LEDs strip left: chan=" .. tostring(chan_left))
gcs:send_text(6, "LEDs strip right: chan=" .. tostring(chan_right))
-- initialisation code
assert(serialLED:set_num_neopixel(chan_left, num_leds),"Failed left LED setup")
assert(serialLED:set_num_neopixel(chan_right, num_leds),"Failed right LED setup")
--assert(serialLED:set_num_profiled(chan_left, num_leds),"Failed left LED setup")
--assert(serialLED:set_num_profiled(chan_right, num_leds),"Failed right LED setup")
function update_LEDs()
  if arming:is_armed() then
    if (timer == 0) then
      serialLED:set_RGB(chan_left, -1, br_flash, br_flash, br_flash)
      serialLED:set_RGB(chan_right, -1, br_flash, br_flash, br_flash)
    elseif (timer == 1) then
      serialLED:set_RGB(chan_left, -1, br_color, 0, 0)
      serialLED:set_RGB(chan_right, -1, 0, br_color, 0)
    elseif (timer == 2) then
    elseif (timer == 3) then
    end
    timer = timer + 1
    if (timer > 10) then
      timer = 0
    end
  else
	if (arming:pre_arm_checks()) then
    else
      serialLED:set_RGB(chan_left, -1, 240, 192, 0)
      serialLED:set_RGB(chan_right, -1, 240, 192, 0)
    end
    timer = 0
  end
  serialLED:send(chan_left)
  serialLED:send(chan_right)
  return update_LEDs, 100 -- run at 10Hz
end
return update_LEDs()
I think front/back arrangement is more convenient for the operator, especially one more familiar with ground vehicles (cars), most of the times you would care where the front of vehicle is to bring it back.
They’re too used to DJI where green is on the back (controls normal) and red is on the front (controls reversed). Personally, I’m with you and use the aviation standard. However I have been known to set up a red LED that goes back and forth as seen in too many 80’s sci-fi dramas.
Points for cylon LEDs
A lighting issue arises when using an integrated propulsion system, such as those from T-Motor. These systems lack the white light that, according to aviation standards, should be positioned at the rear of the drone, with green lights on the right arm and red lights on the left. For my X6 hexacopter, an effective lighting configuration is to have the two front arms illuminated in red, while the remaining arms are green. This allows the drone pilot to immediately identify the front of the aircraft when flying at night.
