I would appreciate your advice on whether I should replace my SmartAP PDB following an accidental short circuit that occurred during electrical measurements.
I was attempting to measure current using a multimeter. The multimeter’s rotary selector was set to DC current, 200 mA range (A⎓ 200m).
With the flight controller connected to the PC via USB and the main LiPo battery connected, I touched the red multimeter probe to the pad marked “+” on the SmartAP PDB. This is one of the pads intended for soldering the ESC power wires. The pad was empty, with no wire or component soldered to it.
As soon as I made contact, a very large spark occurred. After the incident, the system appeared to remain operational, but I have not established whether the PDB or its integrated voltage and current sensing circuitry sustained any damage.
Is it possible to determine whether the SmartAP PDB should be replaced based on this description, or can such an incident leave the board fully functional?
Where was the black probe of your multimeter connected?
Where the probes connected to the multimeter? Does the multimeter has different inputs for voltage and current measurement?
Yes, sparks can have potential degrade or destroy any nearby electronic.
How was the pad prethinned before the spark? In the same kind as the other pads?
Yes, the pad looked like the one on the right side (“-”) before the short circuit occurred.
Today, I connected 2x 16000mAh LiPo batteries (12s configuration total) to the board, and everything seems to be working correctly.
At the time of the short circuit, the flight controller was connected to a computer via USB, and the batteries were also plugged in. I wanted to measure the actual current using a multimeter, as the values:
BATT_AMP_PERVLT: 37.2300
BATT_AMP_OFFSET: 0.63
provided in the manual ( Sky-Drones SmartAP Power Distribution Board — Copter documentation ) appear to be quite inaccurate.
So, than is the question how you produce a short circuit or the spark you have seen. With only one end of the multimeter connected and the other end is isolated now current will flow. But for a spark and the dethinnig of the pad a high current is necessary. This is suspect.
You have no idea how startled and surprised I was at the same time. After that incident, I immediately ordered a clamp meter to ensure I wouldn’t cause another short circuit. The energy of the spark was significant enough to burn away the copper layer, exposing the laminate underneath at the exact spot where the probe had made contact.
Plug in a fresh battery and do a hover flight for 5 minutes or until you’ve used a significant amount of battery capacity
Immediately unplug the battery and charge it, note how many mah’s it took to charge. Let’s say that was 1,500 mah
Download your log and look at maximum Bat.CurrTot. Let’s say it was 1,300 mah
Get your existing BATT_AMP_PERVOLT setting from Mission Planner, let’s say 17
NEW_AMPS_PER_VOLT = OLD_AMPS_PER_VOLT x CHARGED_MAH / LOGGED_MAH With my example numbers, you’d get NEW_AMPS_PER_VOLT = 17 x 1,500 / 1,300 = 19.61
Set the new value in the BATT_AMP_PERVOLT parameter and save to your copter
Fly to check, repeat until you’re happy the new value gives consistent readings
You’d have to check the low current draw manually like you were going to in order to set BATT_AMP_OFFSET properly, but you can just estimate it - put in a value until the battery monitor reports a reasonable positive current draw at rest, something like 100mA or so. The value provided by the manufacture should be correct, or at least close enough.
To measure the current you’d put your multimeter on the 10A scale (for safety) and put the red + lead to the battery positive, and the black - lead to the PDB + input. The 10A scale will still be precise and accurate enough to provide a sensible reading.
You said, you used the battery and a USB connection to a PC.
What kind of PC, Desktop or Laptop? Was the PC connected to AC power at the moment of the spark?
As we can see on the pad the spark had very high energy.
But to produce a short circuit you need a connection between to different potential of the same system. Just with one probe connected to a single pad this is not possible.
Yes, the flight controller was connected to a desktop computer (PC) via USB. The desktop computer was powered by alternating current (AC) from a 230V wall outlet (the standard in the EU).
I think that LiPo batteries with a very high current output contributed to this.
That is why I am very surprised.
I bought a new clamp meter for measuring current (UNI-T UT203+). Now, short circuits don’t scare me.
Hi Pawel,
yes, LiPo batteries can produce very high current but only between the two poles of the battery. So this needs that you made a short circuit between battery + and battery - for example by connecting the + and the - pad on your PDB at the same moment. The destruction on your photo only show a connection to the + pad.
But there is another possible reason for such a spark. This is called ESD (Electromagnetic Discharge). Out of your description of the incident I assume this happend. Caused by the connection of the system to AC on oneside and yourself together with the single pole of the multimeter on the other hand.
The most problem with such ESD is that it can produce failure not only like your damaged PAD but also and at the same time some unvisible latent damages to all electronic in between which can give errors much later
Thank you for explaining what might have happened.
Let’s hope that no actual damage occurred and that all components are still functioning correctly.
For instance, the flight controller (Cube Orange+) was powered from the same power distribution board, but via an integrated BEC—perhaps that acted as a form of protection. I also have two large capacitors (totaling 200µF, 160V) soldered to the board.
I’ve verified that all power outputs show the same values as they did before the incident, and so far, everything is working just as it was.
