Skyviper v2452gps has flown before but after tinkering with Mission Planner and QFlight the controller doesn’t launch the quad. I did the diagnostics and the motors, controls,buttons work.
Probably needs a calibration or three. What messages do you see when connecting with Mission Planner when you try to arm?
I think it wasn’t working because the drone battery was too low. I changed the controller batts and the drone battery and now it works.
When using Mission Planner, the controller isn’t used right?
You still need the controller to be paired. Otherwise, you’ll get a FS_THR_LOW which will cause it to not ARM because it detects you have no controller.
There was a thread in the past that talked about using it with no controller. But I cannot seem to find it. Technically you can set Parameters just right to get it to function fully autonomously. But I think it is typically frowned upon because most regulations require you to be able to take control if needed.
Thanks.
I can’t seem to get any traction in pairing the 2450gps with tower, mission Planner, or qground control.
Got it. Had to change to MAV1. Now to fly a mission. Thanx
Used Mission Planner on my Kindle to create a simple mission and lo and behold it worked. I then added another way point and worked great.
I am so excited now!
nice! congrats and have fun!
