The GPS chip in the Journey is the same as the V2450GPS. The only difference in hardware was the porcelain antenna on the module and a wire harness order reversal.
That last point is important to note… While the connectors are the same, the order of the Journey wiring is a perfect reversal in order of the V2450GPS module wiring.
Yes, the newer module on the Journey does have a cell battery onboard. The GPS table is stored on the SD card in the ublox file, though.
We were hoping the battery would help speed along the lock procedure but in initial tests and evaluations the modules were the same with signal and lock acquisition between the two models. Both from cold start to a quick restart.
In talks with the module dev team, they admitted that the battery ‘didn’t have to be there’ but since we were happy with similar lock time as the previous year (and ever tightening production schedules) we didn’t have time to explore if it was worse without it, so we kept it as is.
(it’s located under the shielding if you want to find it)
Interesting. I assumed the battery would be used to maintain the time between starts and would allow slightly faster lock since knowing the time should help in locating the signal. I guess either I misunderstand how it works or some implementation detail got in the way.
You are correct in your assumptions and that’s EXACTLY what it should do. It just wasn’t built that way on our particular GPS module, apparently, and we didn’t have the time to troubleshoot it and suggest/test refabs of the boards.
