I found this code on the web:
Has someone tested it?
If it works it should work as well on MP.
yes it works well in my copter
Did you compile the full code, which generates a large apk debug file, or ony the one suite for a specific mobile (e.g arm64-v8).
Did you do some code modifications? How are you setting port and ip on qgroundcontrol?
Could not make it run
