Siyi UniRC7 update bug with flight modes
I have updated UniRC7 Ground station and air unit to new version 2.0.8. After this flight mode buttons work using different from old version PWM signals (1000-1200-1400-…-2000) and I can choose only 4 flying modes except 6. First and last two modes make PWM signal that arducopter understand as same flight mode.
@SIYI maybe you can help me?
Should I downgrade software and how I can do that? Or maybe I can change PWM curve somehow on ground station?
It’s on the system tab in UniGCS - you can change the start end PWM values for every button.
But not for flight mode buttons. There no options for this.
Yes there is, I have done it myself. As I said go to the SYSTEM tab.
Hello. Has your issue been resolved? The current UniGCS v2.0.4 version supports adjusting the PWM values for each gear position in “Flight Mode”. You may refer to the video for custom modifications.
I don’t see this functionality at 2.0.8 version. Maybe it depends on region or something else?
Apologies, I am unable to view the link you shared. Please verify:
Remote controller firmware v2.0.8
FPV firmware v1.2.4
UniGCS version v2.0.6
I hadn’t latest version of UniGSC. Now I have all this settings.
Great, enjoy using it.
