It was “Remote control SDK connection method” should have set it to “UART” as well Datalink1 same “UART” then worked ! (many thanks to SIYI Support ! they sent me an video with this steps)
Now I have 2.0.3 RC and 2.0.2 AU (I had 1.3.1 RC and 1.2.0 AU)
How do users get the FPV firmware to upgrade successfully?
On mine, went straightforward. The only thing that didn’t work was last message with “firmware upgrade successful” - I recieved no message. But after 10 mins or so, rebooted the air unit and all was good.
How is your hardware setup?
Do you still remember what was the previous FPV firmware version?
May I know how you verify that the upgrade is successful?
We consider buying some SIYI radios for image transmission. We would like to transmit image files via ethernet over long distance (20km) at sea. If possible we would like to avoid having the ground station of the transmission systems integrated in a tablet. We would prefer low frequencies (2.4GHz) as well to reduce the loss over long distances.
Could someone recommend a version of the SIYI radios for our usecase?
Does the UniRC 7 (normal version) have ethernet? Is there a groundstation version of the UniRC 7 that is not integrated in a tablet/remote?
Is this for use on vessels at sea or for maritime drones?
For maritime drones, the UniRC 7 Pro could be considered, as it can be restricted to a single 2.4GHz frequency band. For maritime vessels, I believe it would be challenging to exceed 3km range.
The standard UniRC 7 model lacks an Ethernet port; only the Pro version features one.
Should a video transmission system be required, both models incorporate Android systems.
My understanding is that it involves transmitting video streams. Ground-to-ground transmission faces numerous interference factors, so achieving a range of 3km would be an outstanding accomplishment.
I do not use QGC in my case. I use MP and UniGCS. But I have to comment for the way Siyi supports the 3rd party GCS in one device is not elegant. UniGGS has to run in the background and quite slow, and unstable.
I do not have a compatible Siyi camera system; I did not conduct that test.
We use unirc7 pro (all updated) and with the latest stable version of qgroundcontrol, video is slow and stuttering (using rtmp). Video is fine in unigcs
