SIYI Mount Pitch and Yaw Control Problems
That is going to be a tough one…
I have set up and succesfully used SIYI A8 camera for at least 20 hours / 40 flights on a copter. RC Channel 5 is set as Mount Pitch, RC Channel 8 is set as Mount Yaw, both of these channels are assigned to two pots on the radio, everything worked very well.
Yesterday I made 5 flights, but starting from 4th flight, the gymbal started presenting issues: when I turn a knob, the gymbal does not execute the corresponding pitch or the yaw command. It freezes where it was, and then after a few seconds makes a jump to some intermediate position, stays there for another couple of seconds, and then again jumps to the next position, until eventually reaching the position which corresponds to the commanded yaw or pitch value.
Initially, I thought that the gymbal may have mechanical binding, but it is not that. The gymbal continues to be fully stabilized (i.e. when the copter inclines, the image remains stable) and..
Also, I have a lua script feature which allows me to have two modes, the standard mode is is when MNT1_RC_RATE==0, and pots control directly the absolute position of yaw and pitch. The DJI-style mode is when I set MNT1_RC_RATE=10, in that mode, when I move the pot from the center position, the gymbal begins slowly to move at this preset rate to the left/right.
Now when the problems began, standard mode freezes in flight, but seems to work on the ground. The DJI style mode works in the flight without anny glitches, i.e. it moves the gymbal in smooth manner, and starts and stop the movement the same instant the pot is moved from the center left/right or back.
So, I am completely lost as to what that may be due…
This is the part of the .lua script:
if not lastzoom then lastzoom=1500 end
if zoom>1200 and lastzoom < 1500 then
lastzoom=1500
param:set (‘MNT1_RC_RATE’,10)
end
if zoom<=1200 and lastzoom ==1500 then
lastzoom=1000
param:set (‘MNT1_RC_RATE’,0)
end
I did another short test flight right now, and it is the same:
On ground, the gymbal worked normally
After takeoff in AltHover and later Loiter, the gymbal worked normally (I stayed in that mode for about 60 seconds), after switching to Acro, the gymbal began presenting these jerking movements, switching back to Loiter did not change anything. switching to DJI-style scan mode worked perfectly, the movement was smooth and slow, and the start/stop of the movement was instantaenous.
I believe, but not sure, that yesterday’s flights also began to present the gymbal problems after switching to Acro mode, although I am not 100 % sure (I always take off in AltHover, and then switch to Acro).
I have a .bin file, but not sure if it is going to be of any help…
Was trying to isolate the problem.
Now, I began to receive errors Prearm and Arm: Mount: Not Healthy. It is about 50 50 now when starting, and one occasion, the message went away after I moved the copter.
Even when I get this error, the camera blinks twice with green lights.
And the scanning mode works fine.
I would suspect that the problem may be the communication in UART, but in the scanning mode the camera follows 100 % the commands, i.e. I have not seen a single drop out in this mode.
Really need help!
Tried to readjust uart cables and connectors. Seemed to work, made a 10 minutes flight, without binding of the gymbal. Still not sure if the uart is the culprit. If it had been a uart problem, neither mode should work, but before, the scan mode was working, the direct positioning mode was not.
What is the radio controller you are using? A SIYI or something else? Are you having those issues at a certain distance away from you or just when you go to acro?
I use OpenTX FrSky Horus X10 with radiomaster elrs 1W tx, it is definitively not an issue with range.
