SIYI MK32 Enterprise Ground Station - 7" Display, 15KM Range, 4G+64G Android, Dual Operator, Abundant Interface
Sorry for any inconvenience caused to your use. We will solve this problem through firmware upgrade in the later stage.
Здравствуйте, у меня возникли проблемы с сопряжением siyi mk32 и mk15 air unit. Прошивки поставил последние:
mk32 - v0.2.1
air unit - v5.3.1
При сопряжении пульт просто пикает, лампочка моргает красным быстро.
На air unit тоже лампочка моргает быстро. Но сопряжения не происходит. В чём может быть проблема?
Actually, i programmed an Arm/disarm switch, connected to my PC via USB and had the radio/video link active too. I was able to arm and test each motor this way. My main issue was a center return throttle and needing an Arm/Disarm swich set on my ground station. I just had my first couple of hover and small control inputs. I have some tuning to do but it’s flying.
Hello everyone.
Please kindly advise on how to upgrade FPV Ground firmware. I think my MK32 came from early production batches, where FPV ground is too old to be able to use the latest features offered by GU/AU firmware available today.
Thank you in advance.
I’m sorry. FPV firmware does not support remote flashing. You need to send it back to the manufacturer for processing.
Hi
So we use mk32 from a long time.
We recently purchased 10 mk32
3 of them are losing range at 500meters itself.
We are unable to figure out the reason.
Is there any requirement for grounding of the anteena to drone frame
Did you ever get a satisfactory answer? I know the MK32 is an older system but there should be a basic channel mixing function like even cheap traditional RC radios have. I’m trying to solve this problem too.
Insulation is required between the antenna and the drone. SMA should not come into contact with metals, carbon fibers, and other materials. Contact points should be insulated with silicone as much as possible.
I am not familiar with your region. But I speculate it is related to high temperature. Please ensure that the Air Unit is placed in a ventilated location and do not remove the active radiator of the Air Unit.
@SIYI
  1. How can I can verify if my MK32 is a standard version or Dual version? I purchased two MK32 separately.
  2. My MK32 firmware is V0.1.6 and I have bound it to Dual version air unit, air unit firmware is V 5.3.1 and i am have constant slow red blinking LED on MK32 but solid green on airunit, can you share the latest firmware for both.
  3. We have purchased the lollipop antenna what would be the best orientation for placing on quadcopter?
  4. What should be the antenna orientation for air unit and MK32 when drone is vertically hovering above the mk32 at altitude of 400ft or higher ?
  5. Can we use 1 directional antenna and 1 omni directional antenna on the MK32 when flying greater than 2km range?
Q: How to determine whether MK32 is a standard version or a dual control board.
A: Confirm through the FPV firmware of the remote control. Standard version FPV firmware: 0.2.6, dual control board FPV firmware: 6.2.6. The same applies to Air Units.
Q: How to check FPV firmware version.
A: 1. Open MK32.
2. Connect the Air Unit.
3. Open the SIYI TX software (or TX, UniGCS).
4. Find Device Info at the end of the menu.
5. Check the FPV firmware.
Q: Why does the LED indicator light of MK32 flash slowly red.
A: The v0.1.6 firmware of the MK32 remote control is relatively old and does not match the v5.3.1 firmware of the Air Unit. Please contact sales for the new firmware or obtain it through our official website’s technical support.
Q: Where is the best place to install the antenna on a quadcopter.
A: Stay away from batteries, distribution boards, electrical regulators, and power lines. Installed in unobstructed areas of the fuselage, such as under the boom and at the rear of the fuselage. Do not cross or bend the two feeders at a large angle. SMA joints should be kept away from each other and not connected to metal or carbon fiber foundations. The antenna is vertically facing downwards. For more information, please refer to the user manual. Manual download link: https://siyi.biz/siyi_file/MK32/MK32%20User%20Manual%20v1.3%20.pdf
Q: Can a directional antenna and an omnidirectional antenna be used.
A: It’s not possible. It is necessary to maintain antenna consistency. For specific instructions on how to choose directional and omnidirectional antennas, please refer to the flight mode section of the user manual.
Dear SIYI Support Team,
I am writing to kindly request the firmware pack for SIYI MK32 version 0.2.4.
My device was accidentally downgraded, and I would like to restore it to version 0.2.4 for stable operation.
Details:
  • Product: SIYI MK32
  • Current Issue: Firmware downgraded unintentionally
  • Requested Version: 0.2.4
I would greatly appreciate it if you could provide me with the firmware file and instructions for installation.
Thank you very much for your assistance.
Please contact technical support via the official website to obtain the firmware package.
Hi, I need help. I forgot the PIN code for my MK32 remote control No. 36453336. How can I reset it?
To re-flash the Android firmware for the MK32, please contact technical support via the SIYI official website for guidance and assistance.
Service and Support - SIYI Technology | Empowering and Building an Intelligent Robot Ecology
