SIYI MK32 Enterprise Ground Station - 7" Display, 15KM Range, 4G+64G Android, Dual Operator, Abundant Interface
I just ordered the MK32. I also purchased the A8 gimbal camera. Both will arrive in the next few days. I am new to building drones. Professionally, I am an automation/PLC logic engineering tech. I hope my industrial automation experience will aid me in setting up and building my first build which is a Tarot 680 Pro. I plan to document portions of the build along with any knowledge I gain with integrating the SIYI MK32/HM30/A8 into my build. I will be sure to post my experiences. Maybe this will help you make an informed decision if the SIYI system is right for you.
You can purchase JST type connector kits from many online sources and make your own cable in any configuration you want as long as you have the pinout.
It seems the SIYI repeater unit placed midway between your maximum desired distance and your transmitter would solve the issue. Of course, you have to physically get the repeater to the midway point. In a mountainous terrain this could prove challenging.
I realize this is an old thread but I recently purchased a MK32. Working on installing it in a Tarot 680 Pro
Yesterday I installed the newest version of the UniGCS app (v1.0.0) on the MK32 to test i out. By doing so, the regular Siyi TX app is gone from the app list and cannot be opened anymore. I then have to use the UniGCS to administrate the TX settings and I don’t like it. One thing is that it always default back to UDP (datalink). This is quite annoying as I often use Usb C to the windows laptop running MP or QGC. It is not possible to uninstall the UniGCS app. When trying to reinstall the latest version of the Siyi TX app (latest version v1.1.256) it asks if i want to update the installed version. When I say “yes” it fails the update/install. All FW on the system are the latest. I would like to go back to using the Siyi TX app and disable the UniGCS app. Please advice.
Dear Ronsand
You can refer to this video to uninstall the software.
Best regards,
SIYI Technical support Wei Chen
General Support
Product Inquiry / Customer Service / Technical support
86 - 133 9244 3839 (Wechat / Whatsapp)
support@siyi.biz
思翼科技(深圳)有限公司
SIYI Technology
Empower and build an intelligent robotic ecosystem.
https://siyi.biz/en - SIYI Official Website
http://shop.siyi.biz - SIYI Official Store
https://www.youtube.com/@SIYITech - SIYI YouTube Channel
IMPORTANT NOTE: This email and any attachment are confidential and may contain trade secrets and may also be legally privileged or otherwise protected from disclosure.
If you have received it in error, you are herewith informed about its status. Please notify us immediately by reply email and then delete this email and any attachment from yo-
ur system. You are prohibited from making use of or copying this email or any attachment or disclosing the contents to any other person.
<Disclaimer in Chinese below, characters may not be displayed correctly.>
重要提示:此邮件及附件具保密性质,包含商业秘密、受法律保护不得泄露。如果您意外收到此邮件,特此提醒您此邮件的机密性,请立即通知我们并从您的系统中删除此邮
件及附件。如果您不是此邮件应当的收件人,请注意不可对此邮件及其附件进行复制或向他人透露其内容。
(Attachment 63871bb319e2de41892b088439713a2a.mp4 is missing)
Thanks for fast reply, but I think the video attachment is missing
Hello. How to use the siyi mk 32 ground station in USB HID device mode?
@SIYI Hi, Support team. I bought HM30(with air unit) MK32(with air unit) and trying to connect my plane to the setup(Video, RC and Telemetry are working) but connection with MissionPlanner does not work. I read in manuals that it works with 0.2.6 Firmware but could not find on Downloads pages. Could you help with this issue, please?
Doesn’t look like they linked the video. I had the same issue a few days ago. I factory reset the whole tablet and it reinstalls Siyi TX. It also maintains the bind with the air unit so you don’t have to redo that. But you will have to completely reconfigure the controller.
  1. Firmware information can be checked through the Device Info interface of the device;
    2.FPV firmware cannot be remotely upgraded. You need to return to the manufacturer to upgrade. Please check if the RC FPV firmware version is 0.2.6;
  2. If your firmware is the corresponding version. Please check if the Data Download has a data volume of over 2000 in the Link Status;
    4.If Data Download is 0, check if the connection cable is connected correctly. If it is less than 2000, check if the baud rate is set correctly. If it is above 2000, check whether the connection method and DATA Link settings between the remote control and the computer are consistent.
On the Siyi UniGCS, there’s a setting under Air Unit Settings. It says PWM settings, but it’s completely blank. What is that for and why can I not see anything there?
Which remote control? What is the firmware of the remote control? Was there a setting option for using TX software before?
It’s a MK32
RC Version 0.1.6
AU firmware 5.2.8
RC FPV firmware 0.2.6
AU FPV firmware 0.2.2
The setting was there on the original MK32 android software (SIYI TX I believe) but it’s always been blank.
Because your firmware version is older. Please update the following firmware for the MK32 remote control and Air Unit: MK32 0.2.1 - Google Drive
I will update and remit back once completed if there are issues.
It works now and I can see the updated settings.
Hello SIYI Support. I have a MK32, N7 with M9N GPS and an A8 camera/gimbal. I downloaded firmware from SIYI for the N7. This is for a large quad. The MK32 is communicating with the air unit, i am using Arducopter/MissionPlanner. The MK32 is receiving telemetry and a good live video stream from the A8 camera. I have completed radio calibration, accelerometer calibration and compass calibration. With the N7 connected to my PC and MissionPlanner, the MK32/air unit in and connected. I cannot get the system to arm. ALL PRE ARM CHECKS HAVE BEEN CLEARED. On MissionPlanner, the last pre arm is the safety switch. I push the button on the M9N GPS for 2 seconds and the LEDs turn green. When I try to arm (throttle down, rudder right for 5 - 7 seconds) nothing happens. Could this be an ESC problem? I am using EaglePower 5215 220kv motors and Hobbywing FlyFun 40a ESCs. Can a problem with the ESCs prevent the system from arming? The "DISARMED message never goes away.
The problem is the N7 is connected to your computer via USB which causes ArduCopter to disable the motor arming function. (HINT: Its a built in safety function.)
My question is why are you trying to arm the motors?
Hello, i I noticed that the outputs of the sticks and various switches were all set to -50. What is set to 1050-1500-1950 in the MK32 channel settings is actually set to 1045-1495-1945 in Mission Planner.Has anyone encountered this problem?
I have two sets and it is reproducing on both (I never had to worry about this before, but it has caused problems when I try to run code in LuaScript, so I’m wondering if this is a feature, a bug, or a misconfiguration, so I’m asking).
