SITL with custom physics using JSON
I am trying to run SITL with a custom physics model and with JSON interface. I have followed the example given here. My physics model runs separately and using a python application I access the state values and send it as a JSON string to the UDP port 9002.
I referred to the SITL - JSON example in the ardupilot repo.
I launch the sitl instance with the -f JSON:127.0.0.1 flag and my python application runs without any crash. I am also able to read and print the pwm servo output from AP. But I think the data transfer is still not successful and I am unable to use mavproxy to execute any commands.
Note: I am running this on windows - cygwin. I don’t face any issues while running the native sitl. Also I am a beginner so I might have missed some small detail. Any help is greatly appreciated. Thank you.
I see the following message in the file \tmp\ArduCopter.log
Setting SIM_SPEEDUP=1.000000
Starting SITL: JSON
Home: 12.915781 77.644586 alt=920.000000m hdg=0.000000
JSON control interface set to 127.0.0.1:9002
Starting sketch ‘ArduCopter’
Starting SITL input
Using Irlock at port : 9005
bind port 5760 for 0
Serial port 0 on TCP port 5760
Waiting for connection …
Connection on serial port 5760
bind port 5762 for 2
Serial port 2 on TCP port 5762
bind port 5763 for 3
Serial port 3 on TCP port 5763
MKFIFO failed with File exists
No JSON sensor message received, resending servos
JSON received:
timestamp
imu: gyro
imu: accel_body
position
attitude
velocity
bus.bus=0 address=0x55
bus.bus=1 address=0x55
bus.bus=0 address=0x38
bus.bus=0 address=0x39
bus.bus=1 address=0x38
bus.bus=1 address=0x39
bus.bus=2 address=0x38
bus.bus=2 address=0x39
bus.bus=3 address=0x38
bus.bus=3 address=0x39
validate_structures:489: Validating structures
Have you sovled this problem, thanks!
