SITL for Ardusub
Did anyone try getting SITL to work with ArduSub. I want to simulate an underwater rover I am not sure if I can get SITL with ArduSub working by my self.
ArduSub hasn’t been merged yet, but is in the process: https://github.com/ArduPilot/ardupilot/pull/5678
It includes support for SITL.
Hi @jakkala_kalvik,
Maybe this can help you :slight_smile:
Clone Ardupilot and update submodules:
git clone https://github.com/ArduPilot/ardupilot
git submodule update --init --recursive
Some packages may be necessary, you can check here the list.
Go to ardupilot/Tools/autotest and run the sitl:
cd ardupilot/Tools/autotest
python sim_vehicle.py -v ArduSub
And than, you’ll have this output if succeed.
SIM_VEHICLE: Start
SIM_VEHICLE: Killing tasks
SIM_VEHICLE: Starting up at -35.363261,149.165230,584,353 (CMAC)
SIM_VEHICLE: WAF build
SIM_VEHICLE: Configure waf
SIM_VEHICLE: "/mnt/hd/git/blue/ardupilot/modules/waf/waf-light" "configure" "--board" "sitl"
Setting top to                           : /mnt/hd/git/blue/ardupilot
Setting out to                           : /mnt/hd/git/blue/ardupilot/build
Autoconfiguration                        : enabled
Setting board to                         : sitl
Checking for 'g++' (C++ compiler)        : /usr/bin/g++
Checking for 'gcc' (C compiler)          : /usr/bin/gcc
Checking for need to link with librt     : not necessary
Checking for HAVE_CMATH_ISFINITE         : yes
Checking for HAVE_CMATH_ISINF            : yes
Checking for HAVE_CMATH_ISNAN            : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE    : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE    : yes
Checking for header endian.h                   : yes
Checking for header byteswap.h                 : yes
Checking for program 'python'                  : /usr/bin/python
Checking for python version >= 2.7.0           : 3.6.2
Source is git repository                       : yes
Update submodules                              : yes
Checking for program 'git'                     : /usr/bin/git
Checking for program 'size'                    : /usr/bin/size
Benchmarks                                     : disabled
Unit tests                                     : enabled
Checking for program 'rsync'                   : /usr/bin/rsync
'configure' finished successfully (1.979s)
SIM_VEHICLE: Building
SIM_VEHICLE: "/mnt/hd/git/blue/ardupilot/modules/waf/waf-light" "build" "--target" "bin/ardusub"
Waf: Entering directory `/mnt/hd/git/blue/ardupilot/build/sitl'
Waf: Leaving directory `/mnt/hd/git/blue/ardupilot/build/sitl'
BUILD SUMMARY
Build directory: /mnt/hd/git/blue/ardupilot/build/sitl
Target       Text     Data   BSS    Total
bin/ardusub  1329446  46606  32896  1408948
Build commands will be stored in build/sitl/compile_commands.json
'build' finished successfully (3.247s)
SIM_VEHICLE: Using defaults from (/mnt/hd/git/blue/ardupilot/Tools/autotest/default_params/sub.parm)
SIM_VEHICLE: Run ArduSub
SIM_VEHICLE: "/mnt/hd/git/blue/ardupilot/Tools/autotest/run_in_terminal_window.sh" "ArduSub" "/mnt/hd/git/blue/ardupilot/build/sitl/bin/ardusub" "-S" "-I0" "--home" "-35.363261,149.165230,584,353" "--model" "vectored" "--speedup" "1" "--defaults" "/mnt/hd/git/blue/ardupilot/Tools/autotest/default_params/sub.parm"
SIM_VEHICLE: Run MavProxy
SIM_VEHICLE: "mavproxy.py" "--master" "tcp:127.0.0.1:5760" "--sitl" "127.0.0.1:5501" "--out" "127.0.0.1:14550" "--out" "127.0.0.1:14551"
RiTW: Starting ArduSub : /mnt/hd/git/blue/ardupilot/build/sitl/bin/ardusub -S -I0 --home -35.363261,149.165230,584,353 --model vectored --speedup 1 --defaults /mnt/hd/git/blue/ardupilot/Tools/autotest/default_params/sub.parm
which: no osascript in (/usr/local/sbin:/usr/local/bin:/usr/bin:/opt/android-ndk:/opt/android-sdk/platform-tools:/opt/android-sdk/tools:/opt/android-sdk/tools/bin:/opt/cuda/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/patrick/.gem/ruby/2.4.0/bin)
Connect tcp:127.0.0.1:5760 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from tcp:127.0.0.1:5760
Init ArduSub V3.6-dev (cMAV> c55e5a8)
Free RAM: 131072
Firmware change: erasing EEPROM...
done.
load_all took 0us
0 0 0 validate_structures:188: Validating structures
DataFlash_File: buffer size=16384
online system 1
MANUAL> Mode MANUAL
APM: ArduSub V3.6-dev (cc55e5a8)
Got MAVLink msg: COMMAND_ACK {command : 520, result : 0}
Received 790 parameters
Saved 790 parameters to mav.parm
No waypoint load started
APM: Barometer calibration complete
Init completefence breach
APM: EKF2 IMU0 initial yaw alignment complete
APM: EKF2 IMU1 initial yaw alignment complete
APM: EKF2 IMU0 tilt alignment complete
APM: EKF2 IMU1 tilt alignment complete
APM: GPS 1: detected as u-blox at 115200 baud
APM: EKF2 IMU0 Origin set to GPS
APM: EKF2 IMU1 Origin set to GPS
APM: EKF2 IMU0 is using GPS
APM: EKF2 IMU1 is using GPS
QGroundControl will connect to it automatically.
Thanks for the help! I did as was recomented here
WHERE I HAVE TO PUT THIS CODE IN QGROUNDCONTROLL please tell
You have no code to put in QGC, you have to run SITL following these steps “SITL Simulator (Software in the Loop) — Dev documentation” then follow the steps of @patrickelectric. QGC is only the interface between the vehicle that is simulated and you
