SITL crashes when used with X-plane 11
00000008.BIN (856 KB)
unfortunately as I am only level 1 I am unable to give the stack dump.
I am using the FX-61 with the parameters provided with the plane
How do you run SITL - on command line with you own compilation or through Mission Planner?
Where did you get the FX61 model from? The standard plane parameters are probably not the culprit, but I doubt that they will work well…
I got the plane and the parameters from x-plane.com and I launched the SITL from mission planner version 1.3.75.1 build 1.3.7961.38854 on windows 11
