SITL and UART communication
Hello guys,
I am trying to work on a project using a LoRA module to send mavlink packets over the network. I have a few doubts. But first I will give you a rundown of my setup so you can understand my problem better.
I am running a SITL simulation over my computer. I am connecting my esp8266 over USB and interfacing the esp8266 to a rn2483 lora module. The lora module works fine and I am currently able to send mavlink messages using an intermediate python script on my computer.
I am curious to establish a 2 way communication between my esp8266 and the SITL instance. I would like to request only specific open drone ID packets from the SITL instance.
Now where the problem is:
  1. I am using sim_vehicle.py --out=“/dev/ttyUSB0:57600”. This works fine but the buffer gets flooded with messages and lora is unable to transmit after a while.
  2. GPT suggested using -A “–uartA=uart:/dev/ttyUSB0:57600” this prompt to establish a 2 way communication with the esp8266 but I get an error on my terminal saying - SIM_VEHICLE: Run MavProxy
    SIM_VEHICLE: “mavproxy.py” “–out” “127.0.0.1:14550” “–master” “tcp:127.0.0.1:5760” “–sitl” “127.0.0.1:5501”
    RiTW: Starting ArduCopter : /home/adop/Documents/ardupilot/build/sitl/bin/arducopter -S --model + --speedup 1 --slave 0 --uartA=uart:/dev/ttyUSB0:57600 --defaults …/Tools/autotest/default_params/copter.parm --sim-address=127.0.0.1 -I0
    Connect tcp:127.0.0.1:5760 source_system=255
    [Errno 111] Connection refused sleeping
    ^CSIM_VEHICLE: Keyboard Interrupt received …
I am a little confused atm. Is sitl unable to support 2 way communication between esp8266. Is there a better method to work with this setup ? I don’t have a autopilot with me.
Thanks a lot in advance. I look forward to your replies.
