Showing wrong ESC telem data
Team,
I have set Batt_Monitor to ESC and enabled the respective params. The data showing is incorrect. At ground tests, the ESC curr & ESC volt are showing 42A and 10V.
Drone Details:
10 inch platform, using custom arducopter firmware 4.7.0
TBS 4 in 1 ESC 8s- 60A
6s battery. Need help in this.
Thanks in advance.
PARAMS.param (18.0 KB)
Log
Try turning on Extended telemetry SERVO_DSHOT_ESC,3
Also AM32 likes a faster update rate SERVO_DSHOT_RATE,3 or 4 based on your CPU load.
I have tried your suggestion, but the problem persist
I’ll be working with one of those ESCs today. I’ll see if they include the current in the dshot telemetry.
Not likely. I think 4-in-1’s with one main shunt resistor, like almost off of them have, would need an additional device to put the current signal into the telemetry stream from the 4 ESC’s.
Recent lengthy post about that.
One more comment to make. Fettec had a solution to this with One Wire, which was really 2, until they went into liquidation. And Matek had a project for a 4-in-1 with a common processor and a serial bus. Never saw the light of day AFAIK. It needs a solution. Airbot’s solution was great but adds cost and weight and a single main source of current in the telemetry stream would be better than nothing or analog.
More news. Hargrave was nice enough to reply to me about their nanoDRIVE 4LPi ESC. Shunt resistor for each section so individual current is available via Bdshot or CAN. Very cool!!
