@Verloop
The crash could have been prevented if you had taken more care when studying the Wiki, especially the sections on VTOL and rangefinder, or if you had shown better airmanship.
Wiki:
In the wiki (Rangefinder Setup: RangeFinders Setup Overview — Plane documentation ), you will see a reference to the RNGFND_LANDING parameter (Rangefinder Landing). This explains how to use the rangefinder to measure altitude during landing.
As @xfacta Shawn already mentioned, your rangefinder malfunctions at low altitudes and is useless until you’ve fixed the cause or installed a better one.
Airmenship:
Rapid drops in air pressure are not unusual in your flying region, so I would recommend preparing for them on longer flights. “High to low, look out below”.
About 50 minutes passed between take-off and the crash. During that time, the air pressure at Bangkok Don Mueang International Airport, just 45 km away, dropped by more than 1 hPa. However, the peak, with significantly higher hourly pressure drops, occurred a little earlier there. While I don’t know the path of the low-pressure system on the day of the flight, it’s quite possible that an even more rapid drop in air pressure occurred in your area during your flight. A drop of 1 hPa in pressure causes the barometric altimeter to read 8 metres too high. Looking at the trend of the two barometers, I would say the reading was about 12 metres too high.
(Although absolute GPS altitude measurements without an RTK fix are inaccurate, this is a relative measurement in which the GPS is more stable than the barometric pressure sensor.) The last barometric altitude reading before impact shows 20 meters (Baro 0, which you used) and 10 meters (Baro 1). Baro 1 seems more accurate to me here, as the drop in air pressure during the flight matches the 10 metres almost perfectly.
As @xfacta Shawn already mentioned, you set the mission path during the approach to just 1 meter above home level for WP75 VTOL_LAND. That’s obviously much too low.
Also, in my experience, it makes sense to apporach by having the drone fly a traffic pattern first at a safe altitude and within safe visual range, so that you can take over via the transmitter and land if necessary.
Most importantly: I’m not familiar with the regulations for Beyond Visual Line of Sight (BVLOS) flights in Thailand. If you flew almost exclusively along the highways without official permission, I would say that was irresponsible.
Rolf
