Setup new HW 130A ESC V4.1 GOV for Tradheli V4.5.7
Hi everyone,
I know there are many topics regard this issue but the information kinda separated to different areas,
I am trying to get help step by step how to use External Gov to take advantage of my HW130A ESC Platinum V4.1 instead of using the Arducopter internal ESC
Starting with the RPM Standardization the document says: I. The motor will enter the soft start-up when user switches the throttle amount from 0 to 40% or above (50%throttle is recommended and the pitch should be 0.00
as of Arducopter setup I have one swich to start / stop the motor after arming.
so there is no throttle stick used here.
so how to do the initial calibration without using the radio TH curve?
now after I solve this issue, I then have to set the THR curve in my ESC to 70% flat to get ~ 1000 RPM, so this is done in the ESC itself? I see when I connect the ESC through the USB cable to the PC the ESC program with Motor Speed page where it’s asking for pinions sizes, see pic;
So basically I should not touch any of the radio settings and all radio THR settings should be defaults.
& The changes only happen in the ESC?
Finley if ALL those issues solved how to read the RPM from my ESC to my tx16S yapuu telemetry?
The RPM cable that is going from the ESC should be connected to aux ch in the PIX6c mini?
Sorry for the many questions…
I appreciate any help.
Ozzy
