I’m encountering an issue in SITL (using Gazebo) when enabling ARSPD_USE.
When ARSPD_USE = 0, the flight behaves as expected, and everything seems normal (see attached logs and graphs for reference). However, when I set ARSPD_USE = 1, the throttle starts oscillating wildly between 0% and 100%. This causes the altitude to fluctuate significantly, creating a rollercoaster-like trajectory.
Has anyone faced a similar issue? Is there a parameter I might be missing, or could it be something specific to my setup?
- Logs of identical mission for both ARSPD_USE = 0 and ARSPD_USE = 1 cases.
- Graphs showing the behavior of the throttle and altitude in both scenarios.
Logs.
