Servo Reverse Motor rotation!
I am buildind an new quad.
TBS Lucid and Mamba F55.
Setting up the Motor config I have come across some problems.
I can’t change the rotation by the SETUP Servo Output or the direct CONFIG to the relevant S1 > S4 servos.
I have tried to do this on a Matek H743 with similar results?
Also it appears that some of the Frame type config appear to be the same eg 12 and 14,
Both FC’s are 4.7.2!
Then tried to do it with a SpeedyBee f405 V4.6.3, same results?
Possible NOT 4.7 poblem but I have to ask somewhere!
Now i’m wondering if there is a problem with Mission Planner latest 1.3.83 1.3.9670.3015?
Hi Rei,
Thanks for the support. I have done much of this and have never had a problem before?
Back to researching the options.
Edit, I’m using AM32, Dshot600 I Have looked at all the relevant functions and I have both soft and full reboot!
And having spent most of the afternoon it decides to work!
Egg on face but persistant!
Thanks.
Hi @GreyBadger,
As @Rei_Kurosawa suggests. The “Reverse” checkboxes can’t be used to reverse the direction of motors. It works for servos but not for motors I’m afraid. For motors, swapping two two of the three wires will reverse the direction or if you’re using something more sophisticated (like AM32 ESCs) there is likely a setting within the ESC itself to reverse the direction
Thanks for the input it’s very much appreciated!
I played with everything, even the checkboxes in desperation ( I did know they were not relevant, but) and somehow crossed functions eliminating one while trying something else!
Re-learnt a lot I had forgotten. All good!
