Servo reverse bit flip
Have the Speedybee F405 WING flight controller on one of Volantex’s Ranger 2400’s.
Everything working fine, however, very oddly, when I reverse the servos, they are working perfectly after updating via mission planner. Tilting the model the servo travel goes the right direction along with everything else, rc control fine, all very proper.
You can even turn the model on and off and it’s still happy, however, after say 30 minutes of no power, the reverse flag (even though the bit is set and as it was when it demonstrably worked correctly) is wholly ignored, and all of my ailerons all turn the same direction. It clearly cannot be trusted and want to get this resolved before the maiden, thoughts of it happening mid-air come to mind! I can then reset the reverse again, looks great, give it 30 minutes, its somehow reversed itself again. With the flag where it was previously working on testing - very odd.
I have several ardupilot models all admittedly with Mateksys controllers, first foray with these cheaper speedybee FC’s, but can’t say I have ever had this problem before.
Just wondering if others might have come across this issue before? On Ardupilot 4.5.
Many thanks!
