Servo motors for ailerons don't move
Hello everyone. I am currently working on my V-tail model and after succesfully completing all the mandatory hardware configurations I ran into a situation where the ailerons don’t move at all. I have set the plane type to normal on my Graupner MX-12 transimtter as to avoid V-tail mixing on it. Further, I have correctly set the input RC channels and my Servo outputs. I confirmed all of this in the Radio calibration and servo calibration windows of Mission planner as the bars move correctly when I move the sticks on my RC transmitter. However, the servos that actuate the ailerons don’t move nor do they stutter. (The V-tail surfaces move correctly and the esc drives the prop motor correctly, after I armed the plane) I am using the servos from the following link(https://hobbyking.com/en_us/turnigytm-tgy-113mg-ds-mg-servo-2-2kg-0-10s-12g.html). The many bad reviews leave me wondering if they are actually faulty. I connected another servo from a different model to my servo output on the Pixhawk and it moved correctly. I did make sure that everything is powered up correctly. Is there anything else I should check before ordering new servos from Hobbyking? If you have any recommendations, feel free to share them here.
With regards,
Emir.
Emir,
This is an excellent test. I believe it proves that the servos are faulty, as you suspect.
Just in case you want to do one more simple test to confirm, try this:
First, verify that you can wiggle your V-tail. (You said this is working correctly.) Then, on the back of your flight controller (Pixhawk?), physically switch the plugs for the V-tail servo and the (not-working) aileron servo. Then try to wiggle the V-tail again. If the aileron does not wiggle, that confirms that the aileron servo is bad.
Do you use any servo extension cables for the ailerons? If so, check them for function and reverse polarity.
