Hi!
Is there a way to automatically rotate the servo gimbal back to the default position if the quadcopter altitude is lower than a specific value?
There’s a landing gear deploying parameter (LGR_RETRACT_ALT) which is similar what I’m looking for.
Is it feasible to do the same function with a servo gimbal?
Thank you!
Allister
(Allister Schreiber)
2
Should be able to do it with a lua script.
Thank you for the guidance!
It seems to be deeper water than assigning autotune to RCx channel
Allister
4
Don’t be afraid of lua scripts. I’m not a coder but I’ve been able to use them for a few things and they’ve been pretty handy.
