Serial XL-MaxSonar unit problem, LV in inch - XL in cm
Hello
In file AP_RangeFinder_MaxsonarSerialLV.cpp
is
// This sonar gives the metrics in inches, so we have to transform this to centimeters
_ reading_cm = 2.54f * sum / count;_
If the 2.54 multiplier is removed then you can use sonar XL connected by serial.
The LV version sends measurements in inch and XL in cm.
The XL sensor works, but the values are 2.54 times greater
What to do to add support for the XL serial version in subsequent releases?
