Serial Ports are not Reading in Same Baudrate
I am using multiple serial ports to read and write data by shorting RX and Tx lines in Pixhawk 6x. I see that When I use multiple serial ports say TELEM1 , GPS1 simultaneously to send and receive data at the same baudrate there is a data drop in GPS1 port. However, when I run in the same baudrate with the same size of data but with GPS1 only it works. They are 2 different serial ports and should work independently right. Is there any relation between the serial ports as to how much baudrate can be used when multiple serial ports are used simultaneously? Can anyone please help me understand this?
Thanks,
Sayan
