Hi all ,
I would like to ask about the official support and limitations regarding serial port mirroring over MAVLink.
My idea is the following:
While the vehicle is in flight, is it possible for Mission Planner (as GCS, connected via telemetry radio , not USB) to mirror or transparently forward one physical UART on the ArduPilot flight controller to the local PC, similar to how ’MAVSerial pass‘ maps GPS data to localhost:500?
More specifically:
- The serial port is a normal UART on the flight controller (e.g. SERIAL5).
- Mission Planner is connected via telemetry radio, not USB.
- The goal is transparent, bidirectional serial data (terminal-style), not sending commands via MAVLink messages.
- Similar in concept to ‘MAVSerial Pass’, but usable during flight and without a USB cable.
I found documentation and examples for:
Serial Passthrough (mostly UART ↔ UART or UART ↔ USB)
‘MAVSerial Pass‘ usage when Mission Planner is connected via USB
However, I could not find any confirmed examples or documentation that this works reliably over MAVLink telemetry links during flight.
So my questions are:
- Is this use case officially supported by ArduPilot?
- If not, is it fundamentally limited by MAVLink bandwidth / safety design?
- Is ‘MAVSerial Pass‘ intentionally limited to USB-connected GCS scenarios?
- Are there any recommended alternatives for accessing an onboard companion computer (e.g. Raspberry Pi) serial interface from GCS during flight?
Thanks in advance for any clarification.
