I am getting a message error in mission planner “sending unknown message 44” how do I fix this. I upgraded to the latest version of mission planner and the error started then. I went back to the older version and the problem is still there. I have an old laptop which hasn’t been used for a while (windows 10) and that displays no error. Its old and slow. Any help would be appreciated.
That should be fixed as per this PR
Should be backported but try the latest Beta version of Plane and see anyway. Or start with updating MP to the latest Beta which really should be done periodically anyway.
The version of plane (4.5.7) is working Okay, i have no problems with it, it’s no problem in my old laptop (windows 10), using an older version of MP. I will update to the latest Beta version of MP and see if that fixes the problem.
All fixed. I upgraded to 4.6.2.
Fingers crossed.
@rmackay9 I get Sending unknown message 64 on both Mission Planner and Yaapu telem LUA for ArduRover 4.6.3. I see there was some change for plane about this, but has this changed for Rover too?
Hi @xen0mk,
Yes, the issue should have been fixed for all vehicles. If you’ve got a log showing the issue that would be great. This will tell us many things like which version of the firmware is being used, which autopilot, etc
Thanks man, I think I fixed it
I had the ADBS streaming from the GSC set to 5hz in SRx and that was causing the issue
Btw I am using ardurover 4.6.3 on atomrc f405 navi. Now that I set that to 0 all is fixed.
