Second attempt, success in manual mode, fail in autotune
Hello
I finished my new airframe which is much better suited to the extra hardware required for a UAV. I was successful launching, flying and landing in manual mode. My goal was to autotune, however I must still have something wrong. When I select autotune, the plane goes nose up, then nose down and refuses to allow me to pull out of the dive until I switch back to manual mode. I have attached the logs and I would greatly appreciate it if someone could help me out.
The problem I was having was due to have the elevator reversed. I missed this setting because the APM Mission Planner does not have the Reverse check boxes which I discovered while using Mission Planner.
