I have following problem. After reboot (command from Mission Planner or REBOOT command from OSD (5 or 6)), there are no logs found by Mission Planner. If I take SD from FC and look at it in PC I see normally all the files. Then I have to copy them to PC HDD, format SD and copy back and then FC recognizes logs. This applies to older versions of AP and AC (pre 4.1) and all Matek FC’s that I own.
I believe it is a bug.
I have searched AP discourse for this issue but did not find any reference or solution.
I would appreciate advice / solution.
Best regards
Ales
