Scheduler loop simplification
I am a bit too lazy to make a commit. Once I prepared a scheduler commit and it was not accepted because I replaced a macro with a template. However, I still think the scheduler could be simplified. Is anything speaking against a loop like this? Was just 5 mins of work.
for (uint8_t i=0; i<_num_tasks; i++) {
        const bool perf_cntr_enabled = _debug > 1 && _perf_counters && _perf_counters[i];
        const uint16_t dt = _tick_counter - _last_run[i];
        const uint16_t rate_ratio = _loop_rate_hz / _tasks[i].rate_hz;
        const uint16_t interval_ticks = rate_ratio > 0 ? rate_ratio : 1;
        if(dt < interval_ticks) continue;
        if (dt > interval_ticks*2) {
            // we've slipped a whole run of this task!
            if (_debug > 4) {
                ::printf("Scheduler slip task[%u-%s] (%u/%u/%u)\n",
                         (unsigned)i,
                         _tasks[i].name,
                         (unsigned)dt,
                         (unsigned)interval_ticks,
                         (unsigned)_tasks[i].max_time_micros);
        // this task is due to run. Do we have enough time to run it?
        _task_time_allowed = _tasks[i].max_time_micros;
        if(_task_time_allowed > time_available) continue;
        _task_time_started = AP_HAL::micros();
        // run it
        current_task = i;
        if (perf_cntr_enabled) {
            hal.util->perf_begin(_perf_counters[i]);
        _tasks[i].function();
            hal.util->perf_end(_perf_counters[i]);
        current_task = -1;
        // work out how long the event actually took
        const uint32_t time_taken = AP_HAL::micros() - _task_time_started;
        // record the tick counter when we ran. This drives
        // when we next run the event
        _last_run[i] = _tick_counter;
        const bool time_exceeded = time_taken > _task_time_allowed;
        if (time_exceeded && _debug > 4) {
            ::printf("Scheduler overrun task[%u-%s] (%u/%u)\n",
                     (unsigned)i,
                     _tasks[i].name,
                     (unsigned)time_taken,
                     (unsigned)_task_time_allowed);
        if (time_taken > time_available) {
            _spare_ticks++;
            if (_spare_ticks == 32) {
                _spare_ticks /= 2;
                _spare_micros /= 2;
            return;
        time_available -= time_taken;
it gets rid of the goto ! I am in :stuck_out_tongue_winking_eye:
Could you do a PR after https://github.com/ArduPilot/ardupilot/pull/7223 get merged ?
About templates, they will be more in ardupilot, just need the time for the core developper to learn to understand them !
Additionally, I wonder if OpenMP would be still a bad idea? On a RPi I was trying something like this and it helps to increase the loop rate. Most assigned functions in the scheduler look safe.
