after many years of building and flying drones, I had finally a setup which worked well for me and ticked all the boxes. - At least as far as I am concerned.
However, earlier this year things took an unpleasant turn and my special drone, and with it my hobby, was destroyed.
Since then I have been looking at other options, but have to admit I miss flying drones.
I looked multiple times at the available options, but would appear there is not much to choose from anymore. - I guess may have to do with what we all learned about the use of drones in Ukraine.
I would really prefer to stick with ArduPilot and already checked out what the Sponsors currently offer. - Appears not much. Most show “Sold Out” on their various offerings.
This brings me to my question:
What is out there, which in my opinion ticks all the following boxes?
Based on Ardupilot
Powerful enough to cope with 40 km/hr winds
Has a payload rating of at least 3kg
Comes pre-wired, motors & ESC’s included
Uses 6S battery ( want to re-use my batteries, which have survived)
Has provisions for a camera like the SIYI ZR10 or A8 to be mounted.
I know there are still some frames available for purchase, but I no longer want to spent the time to run wires, solder, fiddle with connectors,…
But happy to install FC and RC receiver and all the other little things to get it up and flying.
I don’t think there are many RTF/PNP options now. AFAIK in the EU if you sell PNP or RTF you need to certify class compliance and that is very expensive unless you sell a lot of units. Also only “self-made” drones fall under classification exemption.
Unfortunately it looks like kits are your best bet.
Looking at your name I suspect you are german speaking or are located in europe. Therefore I suggest Premium Modellbau from Germany ( Komplette Drohnen & Bundles | Premium-Modellbau ). I have used a few of their RTF copters and they are good quality and well built but a bit more expensive if you really want a RTF copter. Support there is really nice and you can always contact them for a quote on a custom version (e.g. no/more/other batteries, Other RC link, Other FC model, …)
Yes, I have heard of those various rules and regulations in Europe. I also heard that even small drones require the pilot to have some sort of operators licence.
Here in Australia it is still much easier. Even large, heavy drones can be flown without a licence if it is for private use only.(hobby)
Thanks for that link. Looks very interesting. What I did already notice that they still offer various modells which are no longer available from other suppliers. - Perhaps I can find something suitable there. - Danke
I’ve got a Holybro X650 frame kit I’m putting together over time. I got the bare frame as we have lots of other parts lying around already (and a new Hargrave 4in1 CAN ESC to try out), but there is an ARF option too.
The frame and parts are very nice, fits together well and is very stiff.
I’m not sure it would take a full 3kg payload but it might go close to that.
It would be interesting to check on the cause of that crash. You can get spare parts for the Tarot frames. Either reviving the crashed copter or setting up a new one, I would go with inboard ESCs and long motor wires.
Also have some GPS receivers, battery and some other bits sitting around.
A repair was not an option. Had previously a crash - very similar, if not the same cause. Back then I’ve ordered some parts and repaired the frame.
But damage was so servere this time (impact force of around 8G ), that a repair was no longer an option.
As to payload: The Holybro X650 specs do list some payload weights , depending on weight of battery. I’ve got a 6S 16000 mAh battery, which has a weight of about 1820 grm. So in theory should leave me with approx. 2.5kg payload. But I don’t want to max out on that as I’d prefer to have some extra power to spare. - In my area sudden wind gusts can occur and want to retain stable flight under such conditions.
What do you think about the threaded mounting system? The Tarot had a hinge and locking lever system.
Yes, indeed. I did investigate the cause. In fact I found it almost identical to the crash the previous year.
I have got a theory which makes sense with what I’ve seen in the .bin file and the extend of damage found on ESC and motor. However, there is no actual proof my theory is correct.
Let’s just say my particular combination of ESC’s and motors had a technical fault, which so far, has not been documented. …at least from what my reserach indicates.
Feel free to share what you can about the ESC, motor and propeller combination. Also if you added the .bin file I’m sure someone will break that down, if you can.
Thanks for the offer. But I spent hours trying to get more info from the .bin file, but it won’t show / record what I suspect: A build up of harmonic frequency between motor and ESC which eventually leads to unusual current flow resulting in burn out of both motor and ESC.
That is some good hardware! Can’t help to wonder what the ESC timing was set to and the Demag Compenstion. Sorry for your loss
Well I would agree in bringing the ESC inboard, reducing the DC line is a great thing. I have the Holybro X650 (that I’m building out) and a Tarot frame. I never finished the Tarot because I can feel play on the clamp, that is if I shake the arm I could sense micro wobbles.
Holybro frame is rock solid, but it weighs so much more. Rather that though, so the FC can be vibration free and happy! Defiantly get a kit and build another is the way, that’s what I had to do recently. Good luck
The reason why I want a RTF or ARF frame kit, so the combination of motor & ESC is well tested and supported by the manufacturer…one would hope.
It is all to easy to connect any motor to any ESC, do a quick benchtop test and say “It works, let’s mount it on a drone” …But what happens during actual flight may be a completely different story.
Me am moving my parts from a DJI Flamewheel (to the Holybro) that had extended arms to swing 15" props. So I have SunnySky 580KV motor V3508 with some new Hobbywing XRotor Pro 40A ESC, flew good Flamewheel, so I have high hopes it will work again.
Yes,seen those specs. That’s why I will certainly consider it.
However, also been looking at the EFT X950. But that would require a 12S battery setup. …Not sure if I want to head down that path. Years ago started with 3S, then about 5 years ago went to 6S. Don’t fancy yet another power change.
In regard to FC’s I’m considering the Pixhawk 6X. Already got one in another aircraft. What I am not sure about is, if it can actualy handle a Slamtec C1. Couldn’t make it work on a 6C mini due to data saturation…just checked specs: Haven’t much hope as speed and memory are same anyway.
Wouldn’t install it now, but since I’ve got one sitting around I might at a later date attach it to a drone.
I have plans to move to 6S soon for the 15", but I definitely see that not being enough later on. Not sure what I would land on next after that … I suppose I would have to learn to make my own packs first. Either way, planning is part of the allure of this Good luck, have fun and enjoy the path chosen!
Why not fix what you have (had) if you love it so much? A bit of carbon fiber sheet/tube, some 3M DP420 or similar and some electronics and she will be as good as new in no time.
There wasn’t much left to fix. About 80% was destroyed. Besides, carbon fiber is known to hide hairline cracks rather well. So a whole new frame would have been required.
However, 15 years of building, modifying, flying and yes, once in a while crashing drones - unintentional of course- did lead to this particular drone. …Finally the drone which ticked all the boxes for me.
Yes, could start all over again, but the underlying issue has never been found. So, obviously there is no point building the same setup, if, the same motor and ESC combination did cause the crash in the first place. - At least that is my theory as all the data did not provide any conclusive answers to the actual cause. Especially as a year earlier another crash occurred with almost identical data. However, in that case only moderate damage had occured.
The bottom line: Best option would be to use a frame + motor + ESC’s which have been well tried and tested by the manufacturer. This should greatly reduce the risk of such event(s) taking place.
…However,…did manage to keep myself with another project “entertained:”
Why buy if you can roll your own, I have been having a ton of fun designing building 3D frames for my hardware and i think it promotes Ardupilot as a DEV. I not using Ai to design what i do but friends are. Some of the new printers are very fast.
From quad, hexacopters to octo-copters. It is fun for a while, but if you invest lots of time and over the years significant amount of money, then it is getting harder and harder to accept losses due to fatal crashes.
Done also my own frame during COVID. But found due to my large designs, which I require to be of any use to me, the vibration levels encountered were just not practical.
I am aware smaller frames are less likely to have thoses issues, but no use to me if I can’t achieve what I require.
