Saved .param files and the 4.7 renames: how do you keep fleet configs valid?
Hi all,
Over the last few weeks I went through 12 months of ArduPilot master (Sept 2025 to Sept 2026), looking only at commits that changed the definition of a safety-related parameter: arming, RTL, fence, loiter, waypoint navigation, avoidance. 16 commits did, and many of them shipped in 4.7.0.
On a vehicle that’s upgraded in place, the conversion on first boot takes care of the renames, and the Parameter Name Changes page in the docs lists them clearly. The case I’m less sure about is teams that set up new boards from a .param file kept in a repo or a fleet tool. As far as I can tell, a 4.6 file loaded onto a freshly flashed 4.7 board can’t set parameters whose names no longer exist, so those stay at their defaults without much noise. Please correct me if I’ve got that wrong.
A few changes look like they need a human decision even with conversion:
  • ARMING_CHECK to ARMING_SKIPCHK is not a pure rename: the bit meanings are inverted.
  • ATC_INPUT_TC: the 4.7 release notes say to reduce it by about 33%.
  • RTL_ALT (cm) to RTL_ALT_M (m), and PSC_VELXY_IMAX and PSC_ACCZ_IMAX, renamed and now 100x and 1000x smaller.
  • FENCE_ALT_MAX_TP and FENCE_ALT_MIN_TP (added in March 2026): the altitude fence now has an explicit reference frame. The default keeps the old behaviour, but a document that says “fence at 120 m” no longer says above what.
Two questions for anyone running more than a handful of vehicles:
  1. Do you keep a master .param per airframe under version control, or clone from a reference vehicle?
  2. When you move to a new release, how do you check that the file still means what it did before?
Disclosure: I’m building a tool that checks firmware and config changes against a team’s own safety rules, so I have an interest in the answer. Separately from that: if you send me a 4.6 .param (DM here or diego.macias@traceguard.eu, strip anything you consider sensitive), I’ll send back, free, the list of entries that no longer exist in 4.7 or changed unit or meaning. I’ll post any common trap back in this thread without naming anyone.
Full list of the 16 commits, with hashes: traceguard.eu/reports/ardupilot-2026
Diego
Solution:
  1. migrate one 4.6 vehicle to 4.7 and validate manually it’s configuration.
  2. Install AMC on your PC
  3. connect the migrated FC to the PC using a USB connection
  4. use the amc_parameter_export application to export a reusable parameter file that can be loaded in every single vehicle of your entire fleet
  5. Update each vehicle firmware and upload the amc exported file to it.
Makes sense, thanks. Using one migrated and checked vehicle as the reference, instead of carrying the old file forward, solves the fleet side neatly.
The part I’d like to understand better is the manual check in your first step. When a team’s config is tied to a certification or a safety case (an EU C1/C2 drone, say), how is that check usually done? Do people walk through every renamed parameter, rely on test flights, or does AMC point out the cases that changed meaning and not just name, such as ARMING_SKIPCHK flipping its bits or ATC_INPUT_TC needing a lower value?
If anyone else handles this differently, I’d be glad to hear how.
Use diff software like “beyond compare” (great software by the way) to filter out the unchanged parameters between 4.6 and the auto migrated 4.7
Then all that is left out is 60 or so parameters that you can veryfy one-by-one for your EU C1/C2 drone.
Hi @DiegoMacias,
I think most drone manufacturers or operators would do this:
  1. find or setup a vehicle on the previous release (4.6) and download the parameters
  2. upgrade to 4.7 and again download the parameters
  3. compare the parameter list for changes using some kind of comparison tool (I personally use TortoiseGitMerge but maybe an AI would do as good a job)
One thing though is that the final parameter file should not include every single parameter from the parameter list. It should only include parameters that are different from the defaults. The reason for this is that, a bit like airlines overbook their flights, most autopilot’s eeproms are not actually large enough to hold all the parameters. We rely on the fact that most users only set a small subset of the full list.
I think the easiest way to get only the parmaters that have been changed from the defaults is to use the Hardware Report WebTool. Look for the “Save Changed Parameters” button about halfway down the page.
BTW, we have a nearly complete list of parameter changes here at the top of the 4.7.0 release announcement. I say “nearly” because we missed two parameters and ended up renaming them in 4.7.1
  1. PSC_JERK_NE → PSC_NE_JERK (no scaling change)
  2. PSC_JERK_D → PSC_D_JERK (no scaling change)
Thanks Amilcar, that’s helpful. Getting it down to around 60 parameters makes the manual check much more concrete. Out of curiosity, for a C1/C2 drone, are those 60 usually checked against the values recorded in the technical documentation, or mostly confirmed with a test flight?
Thanks Randy, that’s a really clear recipe, and the point about only keeping non-default parameters is something I hadn’t considered. Good to know about the two PSC_JERK renames in 4.7.1 too.
A question for anyone shipping vehicles with a certified configuration (C-class, SORA or similar): how long does that by-hand check take per release, and does it have to be documented for an authority or a customer, or is it internal only?
Thanks both, this is really useful, and sorry for the slow reply.
@amilcarlucas the Beyond Compare step makes sense: filter out what didn’t change and you’re left with the ~60 parameters that need a human. One follow-up: for a C1/C2 drone, do teams keep a record of that check (which parameters were reviewed, by whom, for which release) as part of their technical file, or is it done once and not written down?
@rmackay9 thanks for the point about saving only the parameters that differ from the defaults. I hadn’t thought about the EEPROM limit, and the “Save Changed Parameters” button in the Hardware Report WebTool is the right starting point. Also good to know about PSC_JERK_NE and PSC_JERK_D in 4.7.1. My question: from what you see with manufacturers, how long does reviewing those remaining parameters usually take per release, closer to an hour or to a day?
When you use AMC correctly, you explain why each parameter was changed from it’s default value. So you sign-off every single parameter change independently.
It’s a good starting point, but is not the best one. Flight-Controller Parameter Export | MethodicConfigurator that one is better and more flexible.
1 to 4 hours
@amilcarlucas thanks, that’s very clear: per-parameter sign-off in AMC, and 1 to 4 hours per release. I’ll try the AMC parameter export instead of the WebTool.
