Having checked the logs with the online filter review tool, there is no obvious peaks that would benefit from a notch. Im also tempted to increase or remove the gyro filter.
Is this unusual to have vibrations like this? In this situation is it safe to turn off the gyro filter?
So what filters would you use? The worst prefilter vibe is -55db at 126Hz (blade passage). There are no significant peaks to target with a notch in hover. There will obviously be some vibe in forward flight which perhaps I should check.
This copter is more of an endurance/cruiser so just had a quick cruising flight about 8m/s.
This does show a pre filter peak that i put a notch on, and its 2nd harmonic. Phase lag only -200. Probably that will do I guess.
Slight topic drift. Every craft I have had, copter, plane and VTOL have all had the Y vibe much worse than X&Z. Is that a common theme?
I have almost exclusively used the Matek H743. Perhaps its these FCs?
