RXRSSI on FPV OSD
Is there a way i can get RXRSSI on the OSD FPV screen ? When I try to customize the OSD screen via mission planner, I see the option to add RSSI but not RXRSSI. My receiver provides the RSSI PWM value in the RC14_IN channel. Although I have set up the RSSI parameters correctly, the RSSI value still shows 0. The RXRSSI value shows RC14_IN/2000 as expected.
Note that I am not referring to the mission planned HUD, I am referring to the FPV video feed.
The OSD should show whatever you have configured RSSI_TYPE to
Hello, thanks for the response. Doing this does not seem to work. My setup is as follows:
Version: ArduCopter V4.5.4
RSSI_TYPE = 2
RSSI_CHANNEL = 14
RSSI_CHAN_HIGH = 2000
RSSI_CHAN_LOW = 1000
Below is what I see in the mission planner HUD and Status BAR. And as mentioned, in FPV video output feed the RSSI = 0.
Apologies, this seems to be working now. I dont think I made any configuration changes but when checked again it was working.
