Greetings
I am using rush tank solo 2.5 VTX and matek slim v4
Smartaudio setup is correct. I can switch power with assigned RC5 channel 25 ml , 500ml and 1000ml. ( confirmed visually )
However, it will not switch to maximum power which is 2512 ml when using smartaudio. Even when I enter the value manually in VTX_Power.
Physically when I push the button it dose switch to maximum power.
Have anyone solved this limitation issue in ardupilot with smartaudio ?
