Is there any way to run lua scripts on flight controllers like Matek F405-MINI or other FCs having MCUs like STM32F405 or STM32F407 with 1MB internal flash if i have an external flash available onboard ?
I want to know what configurations or changes i should try to make in hwdef.dat file of FCs with MCUs having 1MB internal flash to enable just lua scripting feature if i have an onboard external flash available ?
The simplest change is to get a 2MB board. The more complicated change is to remove so many features from APM_Config.h file so that the lua scripting can fit in. It will not be easy, and might even not be possible.
i want to do similar thing…i want to set a mission which should be stored on my external flash.My FC is same with internal 1MB flash and connected with an external SPI Flash(Winbond-W25Q256JV) with no SD card on board.The size of the mission is large enough.I have to use external flash.
