RTL Not using RTL_ALT
Hi there Everyone,
So I am using an indoor non-gps system for tracking ( Optitrack) I have working Loiter and automated modes like Circle.
I use the setorigin command in mayproxy to set home pos, but then when I try to use RTL, the copter tries to rise above the setting in RTL_ALT (set to 30cm). I can see in Misson planner that the copter hits 2M alt on the HUD ( and seems to be trying to climb more.)
I am working on a 2m indoor area so going up for RTL is not really an option.
I have insured all settings like Cone and and RTL_ALT_Final are set to 0 or disabled.
Any other ideas what setting RTL is trying to use?
Thanks.
Try Smart RTL - it will try to retrace the path already flown, with redundant sections removed.
What are all your RTL and Land parameters now?
RTL_ALT_TYPE ?
So a quick test of Smart RTL shows that the copter tried to go towards the home point but was still climbing on the way there.
I cant see why the copter would not follow the setting RTL_ALT at 30CM.
I’ll do some more tests today and put a log here.
