RTL_ALT_FINAL with RALLY point on higher terrain
When using RTL_ALT_FINAL > 0 when executing RTL to a rally point well above home point, the UAV does not reduce decend speed to LAND_SPEED, but continue to ground without stopping at LAND_SPEED_HIGH. With RTL_ALT_FINAL = 0, i get expected behaviour.
We have TERRAIN_ENABLED=1, RTL_ALT_TYPE=1, WPNAV_RFND_USE=0, RTL_ALT_FINAL = 1000, RTL_ALT_TYPE=1, LAND_ALT_LOW=1000, LAND_SPEED =35, LAND_SPEED_HIGH =250
I have tested with LAND_ALT_FINAL on 200,500,1000
On the test the rally point was approx 16 meters higher terrain than home.
IRL with Arducopter 4.5.2. With simulator on ArduCopter 4.7
PA:
Do you have a log? Post must be 20 characters
