RPM1 and RPM2 on same input
Is it possible to use the same input for RPM1 and RPM2?
The FC is an AET-H743-Basic; the RPM input is Servo12 (Pin 61).
My configuration would look like this:
SERVO12_FUNCTION=-1
RPM1_TYPE=2
RPM1_PIN=61
RPM1SCALING=0.0147058824
RPM2_TYPE=2
RPM2_PIN=61
RPM2SCALING=0.06617647058823529411764705882353
Would this work, or do I need separate pins for RPM1 and RPM2?
As a GPIO I’m going to expect you’d need two separate pins for RPM1 and RPM2.
Yes, it looks like it.
I tested it and it doesn’t work.
Why do you need two scalings of the same RPM?
You can drop the scaling factor by 2 and you will be able to set notches on harmonics of both signals. Unless both RPMs are mechanically coupled (eg. main and tail rotor) I would strongly recommend using separate RPM sensor to drive the notches as notch tracking failure can introduce significant noise into the control loop.
It’s a heli. RPM1 is the main rotor, RPM2 the tail rotor.
Both have the same rpm source (the motor) but different scalings.
Tail rotor rpm is 4.5 times main rotor rpm.
  1. If you have a clutch you should use a physical RPM sensor on rotor side of the one way bearing/clutch.
  2. I would check if you even need tail rotor RPM to drive any notches
  3. If you do, you can set notch frequency scaling to 1/2 and harmonics as needed (1st MR harmonic (fundamental frequency) will become second harmonic, 2nd MR harmonic will be 4th in the filter etc., TR fundamental frequency will become 9th harmonic).
Thanks for the tips; I’ll give it a try.
