I was wandering if i could use a rpi5 with camera v3 as an IP camera for the HM30 air unit. How could i implement this? Is there a better way to connect them without the need of an hdmi to ethernet converter?
Thank you
Thank you
Implementation methods are diverse; you may set up your own streaming server on a Raspberry Pi, or output the HDMI video signal via an HDMI-to-Ethernet module.
As this involves secondary development, the specific implementation will need to be completed by you.
I’ve integrated an RPi 5 with the A8 mini. They’re connected via Ethernet. BUT, I had to modify the Ethernet cable that came with the camera as it was wired improperly for my application. It took me months to figure this out. Thanks to another user who found the issue and the correct pin-to-pin wiring.
The Ethernet cable included with the A8 mini packaging adheres to standard Ethernet cable specifications. Should you encounter any connection issues, please contact your point of purchase or official technical support for assistance.
